Hi just wondering what hitches everyone is running on outback models and do you like them easy to use thanks for any info
:jaw: So many thing to say.......one of the balls will often get stuck & require a bit of moving forward & backward to get it to let go, while the other is perfect.
Yes I have switched the balls between the tongues.
How to respond....!
As far as i understand, a normal ball and a Hyland ball are both 50mm however the Hyland has a longer neck so the hitch fits it properly - that would explain why the hylan hitch gets stuck on the standard ball.
Please explain you different balls, CJ1177. Maybe what is different about your two balls?
yep you would be pretty much correct, the ball suitable for Hyland has a taller/thicker base flange this is particularly important if you are using a WDH
I'm not disputing what you say here, Bushman, but why would it make a difference if using a WDH?
Just trying to learn.
