17' Series Which generator
19,997
Was going to give mine a run during our 6 hr black out here on Monday but won't be here, you may not use it very much but they sure give you peace of mind...........I run my 2 genny's for about 30 mins each month or so, just put a cup of fuel in and fire them up usually running the shed till they run out of fuel, that way they work when you need them.
Reactions: Sammy D
19,997
Hoping to be at Stand Down Park about 20 mins fromTin Can from this Sunday for a few days while we check out some properties in the area, generally escape the clean up routine of selling house..........might even find something, haven't checked the tides but fish an chips at Rainbow will be on the cards.
We use a fuel stabiliser additive in ours to stop the fuel going off.
Try to give them a periodical run as well.
Nothing worse than needing it and it won't start.
Reactions: Drover and jeff
19,997
Never bothered with fuel stabiliser, mainly as fuel doesn't stay in the can long enough, gets used regularly and the genny's for the most part are stowed empty.
If not using fuel very often then I would use it but only keep a 5lt can at most not 20 odd lts as I do now.
Reactions: Bellbirdweb
Sturah
153
174
49
BrisVegas
Great advice as I do not want any issues when I need it.
17triton
3,717
5,438
Ballarat
I spoke with Truma direct prior to buying and they suggested a minimum of a 2KVA Honda. We will only ever use this for air con. They also stated we should try not to run anything other than air con on it. Went with the Honda 2kva due to size, weight, decibels, and name brand. For some reason they said Honda over Yamaha also.
I gave my Honda 2kva a run with the Truma the other day and handled it fine, even ran on eco mode but was not a stinking hot day. Quite a relief after it failed to run the Heron in the 17-56-1.
Sturah
153
174
49
BrisVegas
That's great news for me as I will be trying it next weekend. After I have the van:)
Reactions: 17triton
peterg
785
2,292
warrnambool
Noooooooo will you generator people man up and do without your air-con and coffee machines and and and !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! we did 6 months without and lived to tell the tale.................................
Damn noisy things in otherwise peaceful camp grounds!!!! many camp grounds in The Kimberley offer generator free areas for normal people!!!!!!!!
Jeremy Johnson
79
131
North Queensland
Used our 2kva for the first time also, ran the air con no issues whatsoever.
It didn't get close to full revs either.
Very glad we chose the 2kva due to weight, size and our requirements, any bigger would be a waste for us.
Reactions: Sturah
