14' Series Wheel Bearings
Ant
17
12
Cairns
Hi All,
does anyone know the inner and outer wheel bearings I need for a 2017 Expand Outback 14.44" ? I wouldn't mind carrying a spare set with me for just in case.
I apologies if this has been covered before. I tried a search but could not find the info.
19,496
If they actually give you the number by Jap bearings from a bearing shop, better quality and cheaper than some caravan shop..... Repack them with grease, wrap in grease proof back in box and vac seal in a bag with a pair if disposable gloves, then they are ready to go, just don't forget the seal as well......
Reactions: Disco Duck
19,496
Because if you don't wear them, Murphys decrees that you will fit your bearings and there won't be a rag, towel or anything handy and you will lean back with your hand in the sand, thusly wiping your hands on your shorts and getting a belt across the back of the head .............. thusly they are PSD's, ( personal safety devices).
Do you mean grease has dangerous chemicals, surely not !!!!!!!!!!!
