What Van to get??
Mark8
30
14
47
Geelong
Can you clarify about your 3 t towing ability.:oops:
My NW Pajero has max tow ball weight of 250Kg up to 2.5 t and up to 180Kg to 3 t. Similar to my old NP Pajero.
So I assume your tow will be a Triton or similar, not a Pajero.
I have just had a major drama and cancelled Jayco van order with excessive tow ball mass on a van I ordered. It had an Empty (Tow) Ball Mass(263Kg) after Jayco info said 175Kg, so be careful about the 3 t Mitsubishi towing ability. For more info see my thread.
http://www.expandasdownunder.com/threads/starcraft-outback-18-55-3-yabbietol-terry-and-ellie.6179/
So in summary please be very careful about Mitsubishi 3 tonne towing.:adoration:
Regards Terry
Correct Pajero has 250kg up to 2500kg and 180kg over 2500kg, triton and challenger have 300kg - 3000kg
Reactions: yabbietol
snip................
:adoration:
Regards Terry
can someone explain the variable Ball weights.............
wouldn't a Max ball weight be just that...................????
not conditional.............
so confused with Bitzamissings
yabbietol
389
824
Queanbeyan NSW
This is how I understand it, but could be wrong I am not a mechanical engineer
( stand clear :director:danger - I am an applied scientist :eek: and former dockyard worker :fish2:).
One would hope the 2015 Pajero might be able to tow 3t with 300kg ball weight.
Not too sure what it is about with Pajero, I believe the Prado just stops at 2500Kg with a ball weight of 250Kg.
It is probably so Mitsubishi Australia can say a Pajero can legally tow 3 t, I am not sure, but rumour has it in NZ it is 300kg to 3 t for the Pajero.
My professional engineering advice recently was it should not be too hard to upgrade physically, about $200 worth of welding in strengthening tow bar and attachments, but about $700+ in engineering certification costs.
It should be noted that two engineers also said to me despite upgrading the tow bar and attachments there is still the size of the rear axel/ bearings/etc to consider and what loading they were designed for and the overall running gear safe load.
Hope this helps, happy for anyone else to provide more technical info.:yo:
Regards
Terry
