Electrical What an interesting solution to flat batteries
866
Imagine the common situation where your batteries are flat, you need to charge them in a hurry, there is no sun and the gene is at home in the shed
What do you do to quickly recharge them? Stay in a CV park for $70 or....
Every now and again someone has a stupidly simple solution - drive to your nearest EV charging station that accepts type 2 connectors. These dispense 15amps at 240V and all you need is an adapter...
20,130
Its not a bad idea really, no good around here no charging station for 60km ....... :) ....................... Imagine parking your ICE vehicle in the bay with the adapter plugged in with a battery charger hanging off it to do your starting battery ..... Then someone with an EV wants to use it and the usual rage event starts ...........................think I would rather use a jump starter or call RACQ.
Old Ute yesterday decided to not start, grabbed jumper pack and all good but later on the old fool stalled it so needed it again ................... looked at label and saw a faded nicko date,01/17 so got my monies worth out of that one... now plugged into shed solar panel to keep it happy.
Reactions: jazzeddie1234
443
Thats different! But as Drover wrote, you might create world war 3 with some EV owner wanting to charge his golf buggy and finds a caravan plugged in. What I have done is rearrange the wiring near the batteries, so can switch over to 12v input from the Anderson plug at the front of the van usually used to plug in external solar panels. I can therefore either run the car for a bit to throw some charge in while parked up, or use some input from the auxiliary battery in the car to assist, or just drive with it plugged in to charge on the run...
20,130
The EV power point at Bingara has enough room for you to park with van alongside and looking online at one of these units, Im surprised that one can have a selection to choose from and they seem to have a decent 240v supply ............... I like gadgets even if I have no use for it, wouldn't buy one .
I have set Big Mal up so that if it hits the fan with the fridge gas I can plug it into the van power supply to keep it running while I get more gas or cobble a repair, all good so long as sun is shining with the back up being the genny, could even plug Ranger Aux into van if its batteries have an issue, 230w on ranger and can connect van panels up to it as well though would be more than the old regulator can handle, 120ah AGM be okay .... actually there's 860w if I put them all together ............
443
Lol...it is always a bonus to have options, a sin to be left with warm beer!!
I carried the 3.5kva genset in the front boot of the van just in case when we did the lap a couple of years ago, never took it out, :(, but, if a person was worried about weights then wasn't ideal to have the extra 35kg over the towball!
Now have 800w in solar, though as I use volts in series - 4 x 18v = 72 volts to pump in to the MPPT to convert to amps... if and when the sun shines...
