14' Series Wall cavity behind kitchen sink
19,506
Not really as your walls are not hollow they are a styro sandwich and you wouldn't be able to hide the cables inside the walls anyway.....better off if you can mount it on a cupboard wall/fridge wall where you can run the wires out of sight thru the floor or where ever your pump is hidden.
composite-flooring-3.jpg Thats a rough idea of what the wall is.........unless its a tin walled van then it's totally different..
19,506
If they back onto a cupboard that's the perfect spot but make sure you can run the wiring hidden and that it will reach before you cut holes.....
