Jayco walls are polystyrene sandwiched between cheap 4mm ply, so zero holding capacityHad a look and i could probably get access to the inside for a plate.
But I'm starting to think Peel rivets and sikaflex will do the job...
A 24in Kogan TV weighs around 2 kg, if your not intending to use a bracket arm, not drive with it mounted and just mounting it like @Brougham's pic then Polyurethane or Polymer adhesive and peels will be ample
The fibreglass is sheet and a couple of mm thick, and bonded to the 4mm ply which in turn is bonded to the polysterene.How thick is the outer fiberglass sheeting?
I was planning on using a basic arm. Just for the tilt function though and won't be swinging it out, so the moment arm would be negligible. And would certainly never be driving with it or the arm still on.
