18' Series Truma Aircon Fault light
Romanog4
Hi there.
New to this forum.
I have a Jayco Expanda with the Truma Aventa aircon unit.
My Unit won't turn on anymore. It has a solid red light on the unit. It flashes 4 times when I try turn it on but does nothing else. Has anyone come across this issue before. It is still getting power. I got it to turn on yesterday and it ran fpr 10 mins then dropped out again.
Any advice would help.
Thank you
1,809
Hi there.
New to this forum.
Thank you
@Romanog4 , this may help:
If it runs for a while and then cuts out, it could be the thermal overload switch connected to the motor. If motor is running hotter than normal, the thermal overload switch will cut off the power until motor cools down. Potentially a fault in the motor windings (short), or run/start capacitor failure. Or even thermostat problem.
Ifit4u4x4
Qld
Hi there.
New to this forum.
Thank you
Did u resolve this issue ? As I have the same thing
ace84
HI I found this on another page. I gave it a go and fixed it mine had a faulty temp sensor
Hopes this helps
Reactions: mfexpanda
