No Options Apply Suburban hotwater unit wont run unless door is open.
Sparksy
15
Been away for past 3 weeks, some of which was offgrid. When running the hot water on gas i have a issue where the Suburban hot water unit will only run with the door slightly ajar. If closed the sound of the flame drops from normal "roar" to a softer sound and eventually the flame fails. Door vents are clear, flame tube is clear , flame rods are bright and as far as gas pressure goes, all 3 burners look fine when running at once.
Managed to use it on gas by tying the door open about 15mm with a bit of wire between catch and door.
Has anyone encountered this before?
20,087
Yes.................. someone had a thread going not that long ago, wish I could remember the cause, Im sure we discovered why.................
854
Twas me! The flame is supposed to create a small current flow across the probes that is detected by the circuit board and that holds the gas solenoid open....until the board develops a fault and is not sensitive enough. The board is expensive so I just open the door each time I use gas.
PS don't try bending the probes as they will snap....don't ask me how I know this
Sparksy
15
Ive cleaned the probes but if it was the board then the board would instantly switch off the gas. In this case the flame slowly looses intensity ( for want of a better word) and slowly reduces over about 2 minutes. If I didnt know that the vents were all clear, I would swear that it was because of a sealed enclosure and the flame using up all the air in there but of course it isnt. Ill try swapping over the board and probe as I have new spares at home.
20,087
Many moons ago I had a drama with a HWS , would start up but would stay on for a few minutes or just shut down once the start time had elapsed, turned out the thermocouple had a bad connector and the poor signal would shut down the gas solenoid .. did lots of testing with the meter before I found it .....
If it works with door open then I doubt its the board does sound like the door closed may be distorting the frame and movinig the thermocouple just a mm away from the flame so it not getting the right temp and shuts the gas off, just can't see how it could starve the air flow though and the gas should shut off instantly ....
854
It could be the probes but the board has a well documented fault where the sensitivity to the flame (well the current measured as the flame passes the probes) is well documented on older boards anyway. I tried cleaning the probes, bending them in and out of the flame, changing the air gate (looks like a hose clamp), adding an extra vent grill to the door....
Definitely interested in what you find!
20,087
I think thats the clue, the flame is either on at full noise or totally out, it doesn't vary as it doesn't have a pilot, its sparks and start ................ To me slowly dying would point to a faulty solenoid thats closing slowly instead of instant shut off or starving of air as you said but its not like the door seals off anything and how would closing the door effect the circuit board, its a most intruiging problem ..................... possibly a combination of faults ................. I too await the outcome .......
I had a similar problem regarding the thermocouple with my 3 way fridge. All was fine for months and then when I was testing fridge at home, found that fridge would light and run for about 15 minutes and then flame would go out and fridge would stop working. After a normal restart some minutes later, same thing would happen again!! As each successive restart happened, running time would reduce before failing. When it got down to under 5 minutes, I realised there was a real reliability problem. Cleaned the flame end of thermocouple, checked positioning in flame and then changed the thermocouple but still failed to continue to run. Then also changed the little cutout connector at back of gas control switch where end of thermocouple joined, and also upgraded the thin light wiring to really heavy stuff for the flame indicator. Result . No more gas flame going out and flame indicator now sits at end of scale in GREEN instead if just struggling to get from RED zone to GREEN . Obviously the flame indicator is a guide to how much current/voltage is generated within the thermocouple when heated. I think it had something to do with the very small electric current generated by the pilot light when heated, and the slow loss of current/voltage leaking away from the shut off valve until the valve finally closed and shut off the gas entirely. That is how I fixed mine and I have no circuit board or door worry about. I hope this gets the thoughts going on checking how much voltage/current is generated within the thermocouple and where current/voltage is slowly "leaking" away by the time it gets to the cutoff valve. As for the "door thing", I am at a loss to even suggest anything!!!
Sparksy
15
Thanks. But the suburban hot water doesnt use a thermocouple to hold the flame failure solenoid for gas flow. I can see your point but the flame detection works by current flowing through the flame from a prob to another probe which is connected to the frame. The control board once the flame starts ignition, has a voltage output to the probe and the board detect current flow through the flame. No flame , no current so solenoid closes.
Ive cleaned the probes and the flame tube and have monitored the voltage on the solenoid valve which remains constant even though flame slowly dies.
Im now waiting for a gas fitter mate to lend me his manometer to see if there is a drop in gas pressure but he doesnt think that is the problem.
Thanks @Sparksy for that info and the fact that the Suburban hot water system does NOT use a thermocouple to keep gas valve open. However, it does require a voltage/current source from somewhere and according to your thoughts, this must come from the control board once flame is lit. Perhaps there is a small capacitor that is not holding charge at times, but is allowing voltage to flow through it without maintaining sufficient charging /constant current to maintain a detectable current flow through the flame to other probe, even if VERY VERY small. Another cause could be a combination of voltage/extremely low current unable to maintain a though circuit? and/or poor connection to frame. Ideas now coming out of remote, but possible fields!!
Incidentally, my understanding of the operation of a thermocouple is when two dissimilar metals are heated in a flame, one metal becomes positively charged and the other negatively charged. As the ends away from the flame have a different electrical potential, a small current will flow between them when connected. Current does not actually flow through the flame. I am happy to be corrected if my understanding is incorrect.
854
A good thing to rule out though. I have heard of a few cases where it was a problem with the regulator
20,087
I thought it was a thermocouple, either way the prongs send a current to keep the solenoid open, looked in my manual and the prongs should test at 1.5 micro amps, I forget how I measured it but need a meter that goes that far down the scale or a calculator................
Is the frame screwed in equally ?? be easy to distort the frame and things move when the door is latched shut....
Have you tried switching off the 12v supply for a few minutes then powering up again, so the board clears memory if any ?
Sparksy
15
The gas switch isolates all power so board etc is isolated when gas is switched off. Ive got hold of another board but doubt its anything to do with it as Ive connected a voltage / current data logger onto the solenoid control supply and its a constant current and voltage even as the flame varies in intensity. Will still have to do a gas supply pressure test as still suspect its a regulator issue.
Hmmn. Running out of options now @Sparksy. Strange that gas supply remains full ON when door is open, but slowly diminishes when door is CLOSED. I doubt that gas supply would shut down like that unless, unless, there is some moveable (loose) restriction when FULL flow is needed. I have heard of small pieces of the rubber diaphragm valve coming adrift and causing issues with older valves and hoses.. Good luck. Looking forward to the results of your investigation.
20,087
Gas supply wouldn't be effected by closing of the door, frame distort as closing moving things ???? or the builders put a screw in the wrong place which moves with door closure ..........??? .......................................
I had a squiz at my manual, found I have a 12v reset button for thermostat, knew about 240v but didn't click for 12v of course that could be a cause of turning off gas if it thinks its hot, wire short as door closes ???
854
The only other obvious thing is adequate air flow to maintain the flame because, as in my case, the flame is strong and reliable when the door is open. That's why I added an extra vent at the base of the door....which did nothing...
Maybe I need a bigger vent
20,087
I fiddled with the door on mine trying to see why it would effect things and the only thing I could come up with was on the air intake on the door there is a baffle which I assume directs the air flow into the chamber, without it the air flowing through the door vent, which is open on either end, could/would cause a venturi effect in the chamber and actually extract the air, hence extinguishing the flame ......................... so I suppose the question is; Is there a baffle panel fitted on the door vent or has it fell off...
You can see a panel in the middle of the vent in pic..............
You could be on to something @Drover!! Has anyone actually been in contact with manufacturer regarding the actual internal workings of this heater?? Perhaps one could get some info on the value of the mysterious "baffle" and its "questionable" importance.
3,040
3,414
Having a similar problem with ours , though only after extended period of no use. I’ve cleaned the probe and checked the gap. What I do know is if you need the control board or gas module you may as well buy a whole brand new HWS as it’s like 50% of the bloody price !
