No Options Apply Starlink Mini ideas.....
19,964
Been watching Starlink from the beginning, the power draw for the first couple of generations is a bit steep for RV off grid and required more $$$ thrown at the set up for off grid in the way of batteries and stuff ....................... Once ROAMing became available I was most interested ,so I watched , researched waiting till things looked good for RV's and then along came the Mini, a 12v unit, more research and the actual power draw is less than my Foxtel iQ4 box, need a power boost though as 12v the power loss seemed to be too great over any distance, easy fix with a 12/30v converter but the price of the Mini was up there, so I laid in wait, Starlink became available from Harvey norman, Bunnings etc and in June 25 the price dropped,saving $150, I was on the road so pounced on one from Bunnings ...
Over the last few weeks the grand plan has been unfolding to have a set up built on the KiSS principle, so no stuffiing around, first off a stand /pole for it, no way I was going to spend $300 for a shop bought pole, I rumaged in my shed and found some alloy tube off cuts, and a irrigation coupling to experiment with, in the end a trip to Mitre 10 for a length of 32mm tube, 1 x 32mm joiner and a 32mm 1" female adapter, it has a stainless steel ring which is ideal for locking the dishy onto...
. 32mm tube.jpg..32mm alloy tube...................32mm1inchcoupling.jpg......32mm-1" female ...................................end coupling.jpg ........... mounted ..
Mail delivered a 12/30v convertor,3.6amp, again the Starlink shops want $150 or even more, I bought mine from a supplier I have used often over the years for aerial parts and bits, $44, this is hard wired into my vans 12v Media circuit which I set up to power the TV/VAST/Foxtel as the Foxbox was having supply problems so a dedicated circuit fitted direct from the load Buss and is switchable from inside the van so I can power it down, the Starlink plugs into it via an Anderson plug on van side, I wasn't keen on the dicky 5.5/2.1 sockets, no power drop at all, if there is my meters don't see it and finally a bracket and fitting welded to Sat Dish bracket for the mast to slip onto with the 32mm joiner which once Starlink is pointed south can be locked in position, it can also be fitted to the rear Sat dish mount on the rear if needed or sat on the ground away from the van..... Time will tell but if I park with a clear North/South view all should be good ............. Sat dish needs due North and Starlink needs due South, though I can aim over trees with the Sat dish, Starlink need a bigger clear view......
Finished.jpg pole ........................joiner adjuster.jpg..... pole direction adjuster ...................TaaDaah.jpg ... with sat dish,..
So the set up has come in under $550 so no more than a decent Mobile Broadband router ie: Nighthawk, subscription cost is bit exxy but with the mini I can pause it when not needed and we don't stream much so no need for huge data , $80 for 50gb, we have Foxtel to cover viewing shows, mostly I want it for the phone connection, not on the phone much, ask anyone who has tried to cal me how hard it is to catch me, but nowadays I find it comforting to be able to ring an Ambo or RFDS if we need it, even the RACQ so the $80 for a month not a biggy especially as only for when touring ...............
Set up should be a couple of minutes as its just plug and play and should be much quicker than my Sat Dish to lock on.............. Time will tell, so I'm itching to get away but thats not till Sept................. surely will be a few mods to it I imagine ....
So while I had looked at loads of Starlink stuff I thought I was doing really well with my set up, a mate just pointed out some Faceache post with similar ideas, though mine is set up without the need for spanners and no ginning around, he reckons mine wins, Im happy either way as it means the grey cells have had a good bit of exercise ............... He's interested, I hope he doesn't want me do his the same way .........................
19,964
Just another expensive toy Paul, I can now use the phone or internet wherever I happen to be, just plug it in, point to the south and away it goes .... Handy if parked out in some of the places we camp especially if one of us has an issue out in the middle of nowhere ......................
Did a power use test and went well only drawing 1.4a at idle and not much more in use, a quick flick to 2.3a when booting up, so about the same as the TV and less than Radio or Foxbox, happy with that and shut down at night anyway while during the day the panels run it all so not much drain on system as at all ........................
19,964
Well a very long test of the power supply I bought has shown throwing big $$ wasn't needed, no glitches from lack of juice for calls or movie streaming, lots of rubbish on the internet about it all though, some for mucho $$$, not surprised really ............................... I bought mine from this mob in Brissie https://www.telcoantennas.com.au/starlink-mini-12v-adapter-144w-dc-dc-booster-conve .
The mini came with a 15m cable so I chopped it in a 1/3-2/3 combo, fitted anderson to both ends, an anderson socket on outside of van with a lead runniing inside with a 5/2.1 female socket to connect to power supply which can be uncoupled in van to run other devices if needed, I also found that by using an Anderson on the outside to plug in the mini that if I want extra distance I can use one of my 8 B&S extenstion leads and it all works, so putting the dish 25mts away is not a problem .............. miniscule voltage drop with the 8 B&S.
The WiFi range is pretty good covering my whole block and inside house, inside the tin van is very good, some good winds and rain didn't give any dramas to my aerial post or reception so don't envisage any problems on tour other than when I pull up I do some quick checks with a compass, clear to South for the Starlink and slightly smaller clearance are to North for the TV Satellite once those boxes are ticked its time to drop the pick ................
One good thing with this Mini is its paused when not in use, so no bills but if like earlier in year our mobile signal dropped off and played up for weeks, I can just activate it on a cheapy plan to tide us over so phones will work and internet for just email and stuff .................
So thats my take on Starlink Mini ...................
19,964
Yeah I got the email, now going to cost $8 a month to park it up, pain but thems the breaks, still cheaper than having a Telstra sim card for touring .... We are saving $50 a month dropping Telstra for Tangerine, so now copping an extra $8 is still within the saving bracket.......... plus I needed a new Nighthawk the old one was on its last legs after some 10 years and a new one was $300 more than the Starlink Mini so still winning.. but its a bluddy pain, these Telcos they all keep changing the game plan ................... I can cancel totally and reactivate when I want it again and being Roam wouldn't be blocked out like residential if over subscribed.
19,964
Well I checked out the Standby Mode, the dribble speed they allow is good for using a phone, checking email and texts but thats about all, pain having to fork out $8 a month for it instead of no cost Pause and pack it in the cupboard till needed but a coffee and slice is even more from bakery so I think I will manage .... Nice to have internet and phone working in a few places we visit where reception is dismal or non existent ...... No phobia about having a phone, like TV if don't want it turn it off, easy peasy ................... plus old means things happen so nice to have a line to Ambo or RACQ ...
19,964
Bought the Mini the other month when it was on special @ $450, was cheaper than a new decent Mobile hotspot .... Bought at Bunnings so I could decide when to activate it .... Mini good for travelling as it is smaller, less power needed and only has one cable ......
19,964
They have upgraded the Roam 50gb plan to 100gb for the same price, that works out better .... I do like having the ability to make a call when no phone signal...
19,964
More plan changes, you can now get a Gen 3 Standard unit for free, well no rental or purchase required with a 3 tier plan set up, $69/100mbps, $99/200mbps and $139 gets you full speeds and unlimited data, with the last plan they will also give oyu rental free a Mini to use when/if you travel it has to be on Stand By when not in use though but you get a 50% discount on plans with it so stand by is $4.25 and the roam 100gb is $40 and unlimited $145 or something if like me no need for the mini I have been thinking about going for the $69/100mbps for home as our Telstra Tower has poor signal, Optus is better but they don't have any real Mobile Broadband data plans and Starlink with no equipment cost is a big saving as their plan costs are comparable to an NBN plan and running my mini at home it all worked very well, especially with a big black out, so putting the bigger dish on house be easy ...........
I'm on the edge of the SEQ congestion zone so would get slugged a congestion fee so its all on hold now as im not throwing $200 at it, sit back and wait till the new ground stations down Brissie way are finished then the fee will go away ............ I can see our Telstra tower on my roof and my roof mounted aerial is pointed right at it and a crappy signal, used a number of aerials and same thing so muct be getting a sidelong view of the cell probably... phone signal is non existant on the ground and we have had enough .............
On the road the Starlink is brilliant especially if you need to make a phone call in a black spot phone area or sitting out at the Dig Tree sort of place....
EDIT: The free dishy deal isn't really free, its a rental free deal so you don't own the Gen 3 or the Mini, have to hand them back if you cancel ....
Reactions: jazzeddie1234
