Solar charging battery.
fishinglizard
216
130
West of Sydney East of Lithgow
I am going away with my brother, his van has 2 batteries and solar, we will be camping with out power for 5 days on a couple of occasions, I have a battery but no solar, so on day 3 or 4 is it a fair option to take one of his batteries out and put mine in for the day to give it a charge? I will be only running lights and charging iPhone/ipad ect so I am pretty sure ill get 5 days out of it anyway, but thought this might have been a good option.
thanks
twscoot
990
1,691
Great idea. It would be best if you can isolate the charge coming in to just your battery though.
blacky
630
680
Townsville QLD
I also use mine to maintain my boat battery, my ride on mower, and my hilux now that I have a cruiser. I just give them a day every now and then on the solar :)
Hubble80
524
303
Moranbah, QLD
I am making a few assumptions but if he has 2X batteries in his van (assumption 1 - 200Ahr total) and solar (assumption 2 - 200+W solar power with a 20A regulator), I think you will be OK. You SHOULD not need you battery and I would ensure it is charged before you go.
Your brothers van should be running the fridge on gas and be using minimal other 12V appliances. Normally we run out of water before we run out of power. Surely his van could be used to charge your phone etc and run lights. If it charges the batteries when driving, even better!
You could make leads (minimum 6mm2) to connect your battery in parallel with the two in the van so you can charge it when and if required.
Capt. Gadget
Dec 1, 2011
1,894
1,843
Busselton W.A.
We camped on the Beach near Exmouth last July for two weeks had sun every day and a 200watt Solar panel on the roof of the van which kept up the 2 120ah Batteries no worries at all also ran the ARB fridge as a freezer off a 100 ah Battery in the Tug charged by my portable solar panel which I think is about 100watt took the genny but didn't need it
