17' Series Sola pannels
23chris
73
17
42
penrith
hello all,
looking at putting sola on my 17.56-2 OB
just tossing up at going 1 all 2 150 watt panels
I have a 120Ah battery
and load is just the normal Led lights, water pump, tv, charging phones and ipads
I do most free camping also have a DC-DC charger installed
what would you do both panels all just the one?
NoWorries
806
1,344
Depends on how much you use the TV and how much sun.
I have 200 a/h of battery and 200w of solar it lasted 4 days of running all that and a 40lt Engel on -16 Freezer
the last two days were overcast and then i needed to get the gennie out.
The car was not hooked up and running at any time during this.
@NoWorries has the good oil. Ive seen a few solar calculators on the GoogleWeb where you can enter all your draw, and the area you intend to use it.
We have 2 x 120ah batteries and 1 x 150w panel. With the continuous sun we've been having we cant put a dent in our supply ... although we just picked up a 2.5kW inverter, so that may change
OH it will if someone forgets to unplug it or switch it off at nights when finished with it :doh: "Hey Mrs Dagree?" ;)
Ha. I suppose its more likely whens it installed under the couch, out if sight.
The 400w one we use now sits in plain view on the bench.
I plan to install a @mfexpanda inspire inverter setup, but lack the required tools, on the road trip. I only collected the inverter today, but will probably rip out one of the 2 under couch CMS GPOs and wire the inverter directly to a replacement std GPO.
The other option was to mount it in the front boot for now and use a longer lead to plug the van into it from the open hatch. Problem with that is ill need much longer batter leads than it came with.
Reactions: Base23 and dagree
Might have to relocate my switch on top of the dinette table so she remembers... or at least sees it ;)
Depending where you are pop back to Perth for a day :D and can help with tools and cable
