Can anyone tell me how to remove the outside roof mounted skylight on my 2010 17.56-2 that is in the shower/toilet. I tried to remove it today as it seems like it should just come off once you undo the clip on the hinge, but it wont budge. The adjuster inside looks like it will just slide out once the cover comes away from the hinge. Im not sure if im putting enough man power into it but I dont want to break it.
The reason I want to remove it is because I can then park it in the carport. I need the extra 50mm of clearance it will give me. :doh:
