No Options Apply Sat Dish Setup
Red1
212
296
Emerald Qld
Hi all, there appears to be an app for everything, so has anyone found one to help in setting up the sat dish. We have one for the antenna for the tv and it works great.
David
David
I have one called satellite pointer (iPhone) which has an augmented reality display that shows you where all the birds are.
Usually a compass is all that’s actually needed to point north though.
Reactions: Red1 and Drover
I been using DishPointer Pro for many years which is on both Play Store and iTunes. It has the augmented reality display, but for around $20 its not for everyone
The one packaged in the Wikicamps App is ok, Ive used that as well on odd ocassions.
Reactions: Bluey and Red1
20,079
I use the wiki camps one for the degrees and a compass, usually have a lock on in a couple of mins. Prefer to be able to have view of TV, find that works better than a stupid meter........be more than happy to trial an auto job, might take me a few years to test it properly though.
There are some expensive bits of gear but still require you to manually adjust the dish/stand, just a flash compass really.
If no phone service I go primitive with a print out.
Reactions: Red1
Glen Bundesen
336
212
Perth WA
David
Hi Dave
What is the app for the TV antenna?
Glen
20,079
There are quite a few out there which use the same data just don't pay for them as the info is actually free ware.
To find a phone tower I use www.oztowers.com it will give you location of mobile towers, is quite readable and easy.
TV location I use an app put out by the Fed Gov called mySwitch but I believe it has been discontinued though mine still works.
Sat Dish I found Wiki Camps App gives all the details you need or you can throw a bag of money and get an auto job, now that would be nice.
20,079
This morning, fitted dish to pole, used the magnetic inclometer set 59 deg , used compass to point it at 9 deg, walked into van fired up STB and nearly fell over, locked on first go 85%, was good enough for me, just went back and tightened the wing nuts, I hope it happens a few more times this run..........At daughters place, handy to fine tune things for a day or so before going bush.
