Reviving an old thread in the hope of some help.
On the 2015 hard tops (bed ends) the barrel can be removed by pressing in the small brass lock slide on the end of the barrel when in the unlocked position
For the Coast hatches (these are meant to be non removable) a small hole needs to be drilled in the right location on the back of the barrel housing. The barrel can then be removed per the bed end barrels
Haven't got to the main door but I'm just trying to get down to 2 keys, 1 door, 1 hatches/lids
Once barrels are removed, head to your local friendly locksmith who will modify them to your preferred key for a fee, or just stick your favourite key in and use a Dremel to file off the end of the pins that still stick out.
My problem is that I have five "BXX" barrels and two "AXX" barrels and all key plates need to be the same for the above to work.
Anyone want to swap 2 Coast "AXX" short barrels (hatches with compression latches) for 2 "BXX" short barrels?
Hoping this finds someone in the same boat...or caravan.
