Hi All,
I just seen this on the ACCC Twitter feed.
There are 2 current recalls for certain Jayco Caravans:
1. The brake wiring connector at the axle may not be fitted correctly. http://www.recalls.gov.au/content/index.phtml/itemId/1030674
2. The axle U-bolt nuts may have been installed with the incorrect torque setting. http://www.recalls.gov.au/content/index.phtml/itemId/1030670
You can check if your chassis number is effected at each of the links.
Mine is, so I have booked it in to get checked, but time was getting tight as it is getting so close to Christmas.
Duncan
Duncan
