Interior Rear wall in Boot
Jaybird
192
72
Gippsland Lakes
I'm installing a diesel fuel tank in my 2012 Discovery boot and want to fix the filter and fuel line etc to the rear wall in the boot. It has a plastic type of covering and I presume a ply backing. If I'm correct can anybody tell me how thick that ply is. Thanks
19,506
Not very, I think my 14.44 it was 5mm if that.........I honestly wouldn't want the tank in the boot, they do vent as well as stink.
Jaybird
192
72
Gippsland Lakes
Thanks for the replies,
Drover, I have built an enclosed box and using a different tank other that the one supplied I was also going to vent it from the tank itself to the outside via a tube.
Johnanbev, How did you mount it on the A frame, do you have a photo.
415
Sunbury VIC.
Couple of brackets and marine ply
19,506
That would be the way @Jaybird , if the cap could vent direct to outside thru a filter, like an old petrol filter that would stop dust and allow the tank to breath, I would fit a drain plug in floor for those times it needs a flush out, unlike petrol one drop of diesel will cover an area the same as a bottle of milk....... last trip I out my 5lt diesel can in a steel ammo box on the rear of van which has my lube stuff, I knew I shouldn't have put it in there as it wasn't long till everything was oily and covered in red dust, even with it cleaned up and the damn can in a bag it escaped........
I quite liked a few shown using a boat tank mounted under the van seemed to be quite a good idea. Filler at front or back.
