Old & Moved Rear bumper white round 50mm tube
Colsar
701
868
Mornington Peninsula
image.jpg Rear bumper , 50mm round powder coated white tube, as is straight of the van as have built new rear bar. Would require a clean and polish $ 80. Melbourne southern area/ Sth east.
Colsar
701
868
Made out of 2 pieces of flat bent into u shapes and welded together to make 120 sq tube, you can only buy 100mm sq tube off the shelf and was a bit small for what I wanted, bent folded door , weld other end closed, etc couple of 40mm sq tube welded on to go under van into original holders, sent to pwr coaters. Purchased lock from jayco, reflectors sticker etc.
All materials, lock etc powder coating, if you added welding and bending get ready to part with 450 ish .
Reactions: bigcol and Delano
Griffo
179
140
69
Royalla, NSW
