Also have one sitting in the garage, located in Geelong. Apologies for jumping on your thread Colin&Sue.
OK So what did you replace them with?
ThanksMade out of 2 pieces of flat bent into u shapes and welded together to make 120 sq tube, you can only buy 100mm sq tube off the shelf and was a bit small for what I wanted, bent folded door , weld other end closed, etc couple of 40mm sq tube welded on to go under van into original holders, sent to pwr coaters. Purchased lock from jayco, reflectors sticker etc.
All materials, lock etc powder coating, if you added welding and bending get ready to part with 450 ish .
