I has a real good look at the smart bar that they sell, which is the "plastic" bar. By all accounts it performs better in every way compared to steel, but it looks naf, and cost $500 more. But if they ever make them look like the steel ones, I'd buy one.
Guess they didn't test drive a faulty oneStill a ford? Well it just got drive.com.au car of the year http://www.drive.com.au/car-of-the-year/and-the-winner-is-20151203-gleyle.html
if they ever drop the "Landcruiser" from a Playdoh, I may look at them
but until then
yeatch...................................
Hitched up the panda to the Prado for the first time today for some test k' s to check the wiring and break controller. VERY impressed with the the Prado. Exceeded my towing expectations. It basically did not notice the 1800kg behind it. Was running Rpm about 200 higher then usual at the same speed. Tried a steep hill, and it did drop back a gear and held it just under 3000rpm the whole way up, did not try and kick down.
So all in all, I'm very happy with the 2.8L.
Bridgestone Duellers worked OK also@dagree is running BFGoodrich - and isn't using a WDH
Sounds like a suspension upgrade required first off..... One thing to try first though is hook the van onto the Prado with a WDH Setup (If you can borrow one that is) and see if it helps.the back sagged significantly with the caravan empty and only 120kg on the ball.
