Interior Paper Laminate..
Dingo
29
Camden
HI there guys just wanted to ask if anyone knows where to purchase the paper laminate used for the draws and kitchen. I have tried Jayco they don't sell it only timber sheets with it already with it?
Thank you
Dove
232
288
Melb, Vic.
As i understand it the laminate is a Jayco item. They buy their panels in laminated. I have heard the furniture comes in ready for assembly.
Browndog21
victoria
Hi Dingo
As said before it comes already pressed up on a sheet of board then cut to size.Certain colors are available in a laminate but it is approx 1.5mm thick that needs to glued to board using contact glue available at bunnings.You cant actually buy the paper and do it yourself,hopes this helps
Reactions: Dingo
