Pretty sure youll find that touring and OB rims are both 6 stud Toyota. Watch that the tyre width and off set dont cause you the issue.Hi,
This may be a silly question, but do outback model wheels fit onto a touring model?
We purchased our 17.56.2 tourer van underslung a few years ago and are playing on going up the centre to Darwin next year from Melbourne. We didn't go with the outback because of the extra weight mainly. Friends have an outback model that we'll be going with. If we decide to go offroad a little bit, i figured the outback tyres would hold up better than the touring ones.Just a couple of simple things are needed to be done with tape measure, pencil and paper to set you on the right path. But why ? is the first part .
Our touring Expanda is 5 stud, I simply grabbed some 15x8 ford pattern sunrasia rims and fitted 235/75-15 tyres(same size as outback models). I also underslung/rotated axle.Pretty sure youll find that touring and OB rims are both 6 stud Toyota. Watch that the tyre width and off set dont cause you the issue.
Do you have any photos that you could post for me pls?Our touring Expanda is 5 stud, I simply grabbed some 15x8 ford pattern sunrasia rims and fitted 235/75-15 tyres(same size as outback models). I also underslung/rotated axle.
Were your original rims steel? Im pretty sure the newer alloys are 6 stud ... but hey, I may well be completely wrong, which the Princess could corroborateOur touring Expanda is 5 stud, I simply grabbed some 15x8 ford pattern sunrasia rims and fitted 235/75-15 tyres(same size as outback models). I also underslung/rotated axle.
LT tyres with an AT tread will do the job, no need for aggressive off road tyres , they just wear more and serve no usefull purpose as they are not driven.......if you have light truck tyres fitted at the moment then no real need if they are in good condition.
