mee mee mee mee toomine is as @Drover has described on my silverline
i did install one of the movement switches that cuts 12v power when parked so it wont flatten the tugs batterymee mee mee mee too
Voltage sensitive relay herei did install one of the movement switches that cuts 12v power when parked so it wont flatten the tugs battery
Hi @chartrock , did a quick check of connections and voltages while getting ready to go off grid again. With no 240 volt AC connected to van and internal battery switch ON, turned selector switch on fridge to BATTERY... No current to fridge from van battery. Connected up van to 240v AC to operate fridge, but before selecting AC, turned fridge selector to BATTERY. Still no power to fridge...as expected! I will check connections again when I hitch up, connecting tug to van by 12 pin plug firstly, and then separately by only Anderson plug line from tug to fridge, with engine OFF and also with engine running. My VSR should prevent ANY power going to fridge ( or anything else too) by Anderson plug (or any other means to other equipment) ) when ignition ON and engine NOT running. If it only supplies power to fridge (and other parts) when engine running, it will confirm my thoughts. I will also check for battery voltage increase as there is a line from tug battery/alternator through 12 pin plug to van loom and then through power diode to van battery. There should be some increase in van battery voltage if connections are as they should be. All other stop, turning and running lights are always checked before we hit the road. Will report findings after we get back on Saturday.Definitely not connected to the van battery and it was not affected
It really depends on how your fridge has been wired up, my old 14.44 as wired by Jayco would not show any 12v draw for fridge from house battery and fridge would only operate if on 12v if plugged into tug. and that 12v feed fed both fridge and Setek, I know that from physical inspection and not just on mine............ the secret is in the Birds Nest........................ I suppose if you look at the back of your fridge and the 12v junction has black and white wires then it is from the birds nest, if it has red/black wires then it has been modded...well thats the way I get an indication and I have played with a few........... personally I prefer to run a dedicated feed from tug and give the OE wiring a miss....................... Of course the best way is to make sure Santa has a multi meter in his sack for you if you don't own one...............Hi @chartrock , did a quick check of connections and voltages while getting ready to go off grid again. With no 240 volt AC connected to van and internal battery switch ON, turned selector switch on fridge to BATTERY... No current to fridge from van battery. Connected up van to 240v AC to operate fridge, but before selecting AC, turned fridge selector to BATTERY. Still no power to fridge...as expected! I will check connections again when I hitch up, connecting tug to van by 12 pin plug firstly, and then separately by only Anderson plug line from tug to fridge, with engine OFF and also with engine running. My VSR should prevent ANY power going to fridge ( or anything else too) by Anderson plug (or any other means to other equipment) ) when ignition ON and engine NOT running. If it only supplies power to fridge (and other parts) when engine running, it will confirm my thoughts. I will also check for battery voltage increase as there is a line from tug battery/alternator through 12 pin plug to van loom and then through power diode to van battery. There should be some increase in van battery voltage if connections are as they should be. All other stop, turning and running lights are always checked before we hit the road. Will report findings after we get back on Saturday.
Geez, you lost me with all that, Boots. When I picked up the expanda, I had no isolators between my tug battery and van fridge. I just thought that turning the selector to ”off” would stop the fridge from drawing current from the tug but it appeared to still allow it to do so. Fitting an ignition controlled relay in the fridge line solved the problem. Simple.Hi @chartrock , did a quick check of connections and voltages while getting ready to go off grid again. With no 240 volt AC connected to van and internal battery switch ON, turned selector switch on fridge to BATTERY... No current to fridge from van battery. Connected up van to 240v AC to operate fridge, but before selecting AC, turned fridge selector to BATTERY. Still no power to fridge...as expected! I will check connections again when I hitch up, connecting tug to van by 12 pin plug firstly, and then separately by only Anderson plug line from tug to fridge, with engine OFF and also with engine running. My VSR should prevent ANY power going to fridge ( or anything else too) by Anderson plug (or any other means to other equipment) ) when ignition ON and engine NOT running. If it only supplies power to fridge (and other parts) when engine running, it will confirm my thoughts. I will also check for battery voltage increase as there is a line from tug battery/alternator through 12 pin plug to van loom and then through power diode to van battery. There should be some increase in van battery voltage if connections are as they should be. All other stop, turning and running lights are always checked before we hit the road. Will report findings after we get back on Saturday.
Hi,Geez, you lost me with all that, Boots. When I picked up the expanda, I had no isolators between my tug battery and van fridge. I just thought that turning the selector to ”off” would stop the fridge from drawing current from the tug but it appeared to still allow it to do so. Fitting an ignition controlled relay in the fridge line solved the problem. Simple.![]()
You may be right @mikerezny, I was new to these sorts of thing back in 2010. It was a Dometic 90L but I don’t recall any other specs but yes, the selector was notched with positions very close spaced.
" Why is it so ?" a great bloke once asked every Sunday on our B/W TV, well because someone thought Jayco will stuff this up for sure, lets put a diode in the 12v feed so nothing goes out where it should come in..................... ( techo stuff omitted so I could understand what I was typing)
