Electrical Not all van fridge electrical connections are the same
19,825
I just did a run with a can of foam between fridge sides and wall, fitting a fan will work better than trying to get the gap closer between fins and outer wall, it will get hot at the back that's how the thing works, no heat its not working, too much heat removal and it won't work either, it needs to operate around the 60 deg mark so a bit of heat bleed us to be expected, your house one is similar.
Reactions: Bluey
