Noisy table
Maxisverymad
60
105
Tawonga Vic
Hi, First night in our 14-44.4 and very happy except sitting here at the table, every time you lean or move on it, it creeks at the plastic clip on the steel slide rail. Has any one else had this problem and fixed it? I'm thinking a silicon spray, any thoughts?
crackacoldie
2,597
3,806
Newcastle NSW
Welcome and congrats on the new van. I would try a little silicone spray to see if that works. Might also pay to check that the rail is tightly screwed to the wall.
As @crackacoldie suggests about the squeaking and screws, and for whats its worth theres been a few whinges about that wall rail parting company with the wall. While you at it, remove the table, unscrew the wall bracket and put it back on with a little adhesive. Jayco walls are about 4mm ply over foam so the screws don't have much to grab. Don't over tighten any wall screws, they'll strip out very easily.
Reactions: dagree and bigcol
