Nitrogen for tyres - yes or no?
Mintox
53
37
I noticed that my tyres on my Swift have green tube caps which indicate that the tyres are filled with nitrogen. If you go looking on the web you'll some benefits but frankly they are for very high performance situations or use in extreme conditions, hardly what the Swift will be exposed to. That and the fact air is comprised of approximately 78% nitrogen anyway so my tyres have at any point 75% nitrogen in them. My issue why bother with it on a caravan? If I am out and about and need to let my vans tyres down for whatever reason where in the hell am I going to fill the tyres up again with pure nitrogen?
Thoughts anyone?
crackacoldie
2,595
3,803
Newcastle NSW
Nitrogen is no good for off road, when you let pressures down and pump back up for bitumen. The nitrogen in the expanda lasted about 5 minutes!
BUSH PALACE
1,534
1,111
LOBETHAL S.A
Weve had this discussion previously , using nitrogen has its advantages in your v8 supercar of F1 but in your van its a gimmick as Cracka said mixed with compressed air becomes useless
Joanne
92
66
I just wished they had put the white letters on the tyres on the outside and not the inside!!!!!! But as for nitrogen in the tyres, when we took our Starcraft 19.6 OB van out for the very first time, we found the tyres were so underflated (32lbs) and towed terribly that we had to stop and put air in them. We carry an air compressor for 4wding so that will suffice for us.
Mintox
53
37
Thanks for the feedback. I figured it was a gimmick. Not sure why Jayco or the dealer bothered doing it in the first place. I carry a compressor so wasnt at all worried about refilling the tyres with air, it just seemed a silly thing to do in the first place.
cruza driver
Hercules
6,551
4,449
Mighty Victoria
Thats why I flipped mine on the rims :D
Reactions: blacky and Joanne
Joanne
92
66
Yes I did read that @cruza driver but hubby won't get it done but I did notice on another post in the last couple of days there are pics of vans at the Jayco factory tour and they are all faced the right way with the letters on the outside!!! Darn!!
DaveS
215
183
Hi
I've been using nitrogen in cars for over 15 years and swear by it, the ex always used to have a slow leak, but after pumping in the nitro it stopped, i had better than average tyre wear on all cars we had, so i reckon it's not a gimmick.
the boss put a nitro generator in when he built the place, so we fill all vans (and our cars) with it.
but i don't use it in the hilux, as i air down when i go 4wding and it's pointless to bother filling back up with it. it changes air more times than i change my jocks :)
Reactions: blacky
relgate
Superstar
2,946
1,902
Sydney, NSW
Hi
More than once per week?
Reactions: blacky
Gibbo
49
40
Bayside
I was also wondering how they create a vacuum in the Tyre before filling it up with nitrogen, because if you cannot do this the Tyre will not be filled with 100% nitrogen. And as the atmosphere is 78% nitrogen if you cannot create a vacuum it will still less than 100% nitrogen. Does this really matter ? I don't really know !
DaveS
215
183
our nitro machine inflates/deflates (or is it the other way round) 3 times to cycle the air out .... i guess some boffin figured this to be the best option without shipping them out on the space shuttle :)
Reactions: blacky and asis
Meanderthals
Aka PhilD
Mar 16, 2012
837
1,356
Near Darwin
In 40+ years of driving and car ownership I've never had a tyre leak (tubed or tubeless) that couldn't be explained by punctures, pinched tubes, faulty valves or stems, delamination, blowout's from bulges, hitting kerbs or rocks or just plain dodgy tyres. Haven't even experienced porous steel or alloy rims either, so far. Never had a tyre unnaturally Nitrogen filled until this van. Personal opinion is that it's a marketing (delete "scam", insert "ploy") for normal use that only financially benefits the Nitrogen suppliers and those doing the filling.
Saw a similar debate recently in some Forum and the slightly tongue-in-cheek comment that if the Oxygen leaks out faster then by constantly refilling with standard air mix then you would be gradually increasing the Nitrogen percentage anyway.
BUSH PALACE
1,534
1,111
LOBETHAL S.A
Hi
Are you being paid off by CIG ????
blacky
630
680
Townsville QLD
I know the feeling @DaveS! I use nitrogen, only because I have it at my disposal... had to 'charge an accumulator' on the weekend .. we mainly use nitrogen in fire suppression systems (because it is inert and is highly pressurised) accumulators (need to be nitrogen charged to achieve pressures, and underground drill tyres which are pumped to 140psi (good luck doing that with a compressor!)
3,032
3,404
Reminds me Pete. Mates dad used to service and sell compressors. He had a batch of 25 or 30 cfm compressors that were ex wartime in real good Nic. The receivers (pressure tanks) were rated to 250 psi with the blow offs set at 200 iirc. Haven't seen a receiver that high since
