Hi
here is an update, as far as I can find out:
There was a batch of 30 axles from Al-Ko identified with possibly faulty welds.
Jayco identified that they could only have been fitted to 200 Jaycos.
Al-Ko have assigned a person to handle the recall and ship out replacement axles.
Jayco are working with dealers to identify vans delivered and those still to be delivered.
Bayswater Jayco had 8 vans to check and mine was the only one found to be faulty.
Al-Ko supplied a complete assembly, but one hub had to be removed when fitting to get
the axle through the leaf springs. The dealer had to cut off the original fitting plates
and weld them back onto the replacement axle. The total job took about 2 hours.
I got to have a look at the faulty axle.
The problem was with the weld between the backing plate and the axle.
The weld had not taken at all to the backing plate. And the plate was not attached at all
to the axle when I saw it.
The van was delivered on time, and we have already clocked up 130 km taking it camping
over the weekend and have had no problems with it.
Yes, I am feeling much more positive about it now.
Thanks for all the helpful responses.
