Hi All
We are now looking at a new 16:49-3 in outback. I am looking at optioning it up with some of the following, and appreciate any comments or thoughts, as some are “dead certs” and others I am not as sure about. I have a budget in mind and am not so sure I will get all this into it.
B2200 Dometic Roof Mounted A/C, How are these draining? Primarily getting it for extra space it offers, Microwave up high, better airflow, but that weight up there worries me even with the extra bracing.
Solar Wiring Provision, Because I will regret it otherwise, but think its a rip off
Control Panel, (water, battery) I really missed this before
Extended Draw Bar 300mm, primarily for extra drawbar storage. I am a little concerned with clearance on driveways, humps etc.
External Shower, Beach side, returning from fishing
Extra Water Tank, Needs to be factory fitted or you cant have a 82litre. Was going to use it plumbed direct to hand pump for drinking water only
Wind Up TV Antenna, because of convenience and I can’t add it later.
Extra Double Power Point Bed End, don’t know if I will need this with larger fridge
150 litre 3 way
Anderson Plug, saw one last week at the showroom and it look reasonable wire, but appeared to only feed the fridge?
External Picnic Table, been advised to get aftermarket one like Bushy’s one
Extra External 12 volt Socket., mounted behind fridge up high to feed 12volt to awning strut for lights.
Gas Bayonet, Don’t know where to put this
Factory supplied battery because it adds to plated weight and its reasonable at $300
Obviously awning, privacy screens etc
150 litre 3 way
