Well, she is home, the holiday capsule.. Had an uneventful trip home and the "towrig" did a stunning job, again. View attachment 12977
Safely home and backed into it's storage area....View attachment 12978
A moment of relief, when the Webber fitted.View attachment 12979
There were a few little things needing attention, the seat base had fabric "pulls", they are getting replaced and little quality control things I touched up, not unexpected, but better than I thought it could have been.
The only question I have is the 12v water pump operation, it sounds like there is air in the line, as it is not a continuous stream, but rather a spatter effect. Is this normal, or should I be looking for a pin hole size air leak? There appears to be no actual water leaks BTW.
Anyway, thanks for check list and support, and I hope I can be of assistance to anyone else at some time.
Mat
Well done nice van!!!!
What model q is in the bag?
I had a similar problem with our disco.
I have found switching the water tank control from the rear tank to the forward tank solved the spattering problem.
But not sure yet on the root cause of the issue.
Let us know how you get along....
