17' Series new battery..
Mattd
12
11
Hi guys,
Just picked up our new 17.56-2 ob and had them wire in for a second battery..
Questions are, is it just "plug and play"? positive to positive and neg to neg?
Will the drifter know it's connected?
Also, I was looking at the setec unit and noticed it said "lead acid for charging only" but the van came with a gel battery..
Also, the van is great..:-D
Thanks Mattd
willobee
235
374
Pretty sure I read in the setec manual (yes im admitting to that) that gel batteries were ok also, will have to re read though to confirm
20,087
Gel okay, mines going good anyway. Just hook up as normal just need to turn battery switch "ON" for it to work.
spiderpig
167
216
Canberra
Does the "Battery" switch need to be switched "On" for the setec to be able to charge the battery in these vans or is that just to switch power sources?
20,087
The battery switch connects the battery to everything, setec, lights etc turn it off isolates the battery. I leave my battery switch ON all the time, that way when on 240 the battery gets charged or kept at charge and when no 240 I can have lights/pump going, I only turn it off for maintenance actually.
When the van is parked up at home the 240 is plugged in, battery ON, water pump and light switches OFF, fridge OFF until 2 days before take off then fire it up so it gets nice and cold, fridge packed the day before.
I only turn the water pump on when not on mains water but always off when on road.
Get into habit of turning HWS ON when hooking water up and shut it down when disconnecting water, that way you won't cook it. Reset button usually works though.
Mattd
12
11
Thanks for that. Im having a play around with the van at night and using a small amount of power, battery only.
The next day, im finding the battery rechagers fully without the bsttery switched on.
My question is, does the battery need to be switched on at the drifter for the solar to charge the battery?
Hi guys,
Thanks Mattd
You will need to change the Amp Hour rating on the drifter (just add the 2 batteries AH together) so it will give you a more accurate capacity measurement, but other than that it's pretty much as you've stated
NoWorries
806
1,344
The solar should be directly connected to the battery so no it should not have to be switched on
