My New 16.49-3 Jayco Expanda Has Arrived
David Spencer
44
42
Can u move the table in ur lounge conversion when not eating. Do u think its better than the 2 bench n table setup
Tonykarter15
77
88
Central Coast
Yes you can. The base has a removable bolt that can allow the whole table assembly to be taken out. I installed an offset bracket at the top of the table leg that allows you to move the table 360 degrees around a 300mm offset. This lets you lay down on the lounge without having the table right on you. I like this option better then the 2 bench option as I wanted to lay down and watch TV if the weather was bad that the 2 bench option didn't allow.
Bossco
4
Redhead
Has anyone modified or had a new rear roof handle manufactured to fix the toilet door issue? Im thinking of getting one made but would love another solution if anyone else had already done it.
Tonykarter15
77
88
Central Coast
what i ended up doing is simple enough - 3 blocks of foam. I open the shower door, put 1 packing piece of foam at the top and bottom, drop the poptop handle down, and use the third piece of foam to wedge between the handle and open door. I did 15,000km last yr with it and had no issues at all.
Brett Williams
Orange NSW
I removed the roof lifterm and put in some lynch pins so they can be removed once.the roof is down and the toilet can be used
Simple and better than the standard rivits
I just used a thin blade on a 5 inch grinder
Brett Williams
Orange NSW
