My overly complicated caravan install pictures. I wanted to mount it under the floor to save space and mix fresh air with cabin air. Pic1: The box has an inlet chamber on the left and open on the right to ease hot duct connection. The aluminium angle is used to attach to the underfloor. The side attached to the heater can be removed from the rest of the installed box for servicing. Pic 2: A simple tank mount that is hidden by the spare. Pic3: installed for testing but no ducting attached. Pic 4: Behind the door step I made a complicated cowling to pick up cabin air from an existing floor vent. Pic 5: I used 2 layers of carpet screwed to box with a bolt through just 1 layer. Seems quiet enough. Pic6: Now experimenting with a few layers of cleaning cloth to determine ratio of cabin/fresh. I have found this cloth to be a good cheap dust filter material in the aussie outback
