17' Series Mobile auto elec required
Digger12
Western suburbs melbourne
gday guys, im having some problems with our van blowing the fuses when using the water pump and water heater. Does anyone no of someone that can do on site repairs - western suburbs Melbourne.
We just googled 'mobile auto electrician' and found one...but several thousand kms from you.
and it worked out vey well.
Reactions: dagree and bigcol
19,906
More info....which fuses ??? as HWS only has 12v for the igniter for the gas and if running on 240 then it would have nothing to do with the water pump blowing so must be a bad connection more than likely in your pump circuit.
If it's 240 circuit breaker popping and it happens only when activating the water pump then you are very close to getting curly hair forever, disconnect 240 and get a Lecko.
