Hi burnsy not 100% about nsw. My last van was from Sydney and was repairable. That was 2010 though.
Here's one I found now that has a repairable status
http://www.manheim.com.au/damaged-v...-2015-atm-1-408kg?referringPage=SearchResults.
But it does say Qld. So really QLD is blessed unlike the other states..
I replaced the walls  right side completely. Left side only the front 25%.
Roof was not bent just looked it, for the walls weren't supporting the 200kg load. The nose cone fiberglass was snapped in 6 places. I glassed it back up, bogged it, primed and 2k paint.. Hard lids, canvas was fine, a few touch ups here and there. A few of the internal cabinet panels I replaced or repaired, they come apart easy as.
Replaced the roof alloy extrusion, as per photos on my lawn.. Ex jayco only. Door frame outer ex Camec. Right window still 2 months away but I can live without it for the moment. $400 window and no stock Camec.
Ok here's my parts list: ( from memory)
Awning
Awning arms
Fiberglass skin 2mm x 8 lineal metres
6 sheets 3 mm ply
5 sheets 2.7mm polyester white internal ply
5 sheets 19mm polystyrene sheets.. Hahaha they cost $15 all up.. How do they make money?
Door outer frame
Roof extrusion
Fiberglass mat, resin, bog, primer paint.
Heaps of white sika  about 6 sausages, and one tube black.
Laminex sheet to replace bench tops.
3 sheets 12mm marine ply
19mm alloy SHS 8 lengths x 8'metres
25mm as above 1 length
Body extrusions outer sections and mid one length only.
0.9mm checker plate powder coated black. Replaced all lower pieces.
3 sheets crappy jayco 12mm paper laminated ply. This is the cabinet material. Paper laminated really?? True quality.... NOT!!!
Handful of screws pop rivets, glues for applying the sheets etc.
150x50x3mm duragal for draw bar
Front hatches
Spray on deadener for nose cone lower.
A handful of other small junky clips brackets etc.
2 gas struts
power inlet sockets.
New AGM battery
Gas bottle brackets and reg.
3 cartons of beer, 2 bottles of Jim beam, 2 arguments with the missus, sunburnt 10 times, 5 alloy shavings in my foot and a mild case of welding flash. Oh and accidently unplugging the deep freezer for a lead to run the grinder on and forgetting to plug it back in... That was not a good experience.
WOVi fee
Roadworthy
Registration
Insurance
Camping In 4 weeks
