Our Sink mixer tap has come loose on our 14.44. Pulled a couple of drawers out to see how it was secured underneath but cant see anything, just the 2 hoses going up into the hole for the tap in the bench.
Can anyone shed some light, do i need to remove the whole sink to sort this out?
When mine come loose I found the nut was loose just tightened it up with a 10mm tube socket then put a nyloc nut on it as well to stop the bugger coming loose again.
Common problem, the one in our Panda came loose also, thought was going to have to remove sink also which is a mongrel of a job, manage to tighten enough with some open ender, till it got done properly at service
Ok thanks. I thought i had a pretty good look up under the sink where it goes through but couldn't see any sign of a retaining nut, might have to look a bit harder by the sounds of it.
