Interior Limited hot water
Themoneypennys
22
16
Hi guys,
Away with the family and only seem to be getting a couple of minutes of hot water before it's re-heating again. Used it on previous trips and had no probs with a lot more water.
Any ideas????
Greeeny
59
Cheltenham, Vic
We run our hot water on gas as it reheats much quicker, also if you are using the water-pump and the tanks, we find the hot water will run out much faster. When we are at a Caravan park we just use the mains water pressure and the gas heating (no pump) and generally the water lasts longer, it is only 20 liters though. The shower process is just wet, soap up then rinse, not continuous running water.
Hope this helps a bit.
Pace
2,052
1,349
melbourne
Dido here for the Paces.
