UOTE="Ligedy, post: 57176, member: 2338"]3rd Water Tank Install.
Piggy-backed the plumbing (filler and breather hoses) off the second tank and put in ball valves so water can balanced (and monitored using the existing RV control panel wiring) between the two tanks, or shut off when not needing to cart around extra water.
View attachment 18230 View attachment 18231 View attachment 18232 View attachment 18233 View attachment 18234 View attachment 18235[/QUOTE]
I am wanting to fit a third tank as well. I noticed the chassis cross braces are reversed where the standard tanks are fitted. How did you get the tank to fit up tight to the floor like the standard tanks are fitted? or have you dropped it a fraction to accommodate for the
steel cross sections.
