Leveling a dual axle trailer with independant suspension
Macca_75
680
596
SE Suburbs, Vic.
Hi Guys,
Waiting on delivery of our new 20.64.1 Expanda OB
When I'm looking for leveling ramps, do I need 1 or 2 given it has dual axles and independent suspension?
Thanks in advance.
WHHEMI
357
562
Yarra Valley
I use two on mine, but if you get some make sure one fits between the wheels, the ones I have are two piece, when free camping we also dig a hole or two to level van depending on ground.
Reactions: bigcol and Macca_75
19,503
I'm lazy I just use one or a block of wood, have found one wheel lifted will get it level with no ill effects, saves a lot of ginning around.. At the moment Big Mal has a 25mm block under one wheel to get it level . (Big Mal has 265 75 x 16's)..
Only need to carry one ramp to go with the 6 wood blocks for under the stands....................seen some folks stuffing around for ages then get the s;;its when I roll mine on one and it's done.
3,031
3,401
Do you have independent @Drover ? One works okay on load sharing duals. actually there used to be a trick for load sharing 4 wheel vans you ran up one till level then placed the other in front and rolled the other way down till it was even in both and it would be the same. Iam with with Mf and gone back to using one where I can on the jtech suspended vans but it only works so far. but if I was buying Ramps again I'd buy those andersons or the smaller ramps that fit between the wheels. The two piece ones are a pain. If I was buying a van again I'd so try and get air suspension which you can level from inside with push of a button while having a quite ale!
Do you have independent @Drover If I was buying a van again I'd so try and get air suspension which you can level from inside with push of a button while having a quite ale!
You've given me an idea @achjimmy. I already can inflate and deflate my Polyair bags on the tug from inside the cab, time to investigate Polyair's with the JTECH independent now.
Love the idea.
19,503
Yep they are independant, can't recall what Corromal call the set up.................Individual air bags with an auto level controller shouldn't cost much...........................lol.
Macca_75
680
596
SE Suburbs, Vic.
Reactions: bigcol and Drover
Reactions: Drover and dagree
19,503
These bad boys are around $4,500 -
Cowabunga !!!!!!!!! add that to the van mover thingy's at about $5K, and not only is the wallet cactus but the weight allowance on van would more than likely be maxed out, save a lot of packing though...................................unlike the others above I will stick to my $6 spirit level from Supercheap and handraulic vertical position unit.
