Leaking Van
MolongMick
618
112
53
NSW
How did you check if the breakaway battery was not charging @MolongMick ?
@Brad, The breakaway alarm in the car kept beeping at me every time I put the foot on the brake. With the car hooked up the unit should show a charge being put into the battery, an orange light on the unit will be on showing it is in charge, mine wasn't. There is a wiring issue on the tug, will sort that out today.
Hope they fixed it Mick, I'll have to check mine now. I always thought the ctec charged the breakaway battery on mains anyway?
Brad
2,645
723
Rowville, Victoria
Interesting.... Without the warning light how do you check the battery?
MolongMick
618
112
53
NSW
In NSW. it is law to have a monitor in your car to warn you if the battery is flat. Not sure about Victoria. In my opinion, for $100 it is worth it.
Not sure how to check the battery on the unit itself though.
There was no power going to the Ctec unit from the tug, I have fixed that by piggybacking off the fridge supply in the cars 12 pin plug connection. Seems to be doing the job.
relgate
Superstar
2,946
1,902
Sydney, NSW
Good work Mick. I hope that doesnt affect your fridge's performance too much while travelling. I guess it's not too hot at the moment.
MolongMick
618
112
53
NSW
There
@relgate, yeah I was worried, but checked the voltage and everything was fine, no drop in voltage from before to after, the fridge line was quite a heavy line so I really dont think I'll have any dramas.
gspy4u
235
112
Ipswich
the breakaway unit in ours has a check button on the unit itself under the seat. You press the button and if it lights green the battery is charged
