17' Series Kitchen Drawer Secure Locks
Disco Duck
315
586
Adelaide South Australia
I'm sure there will be a thread to cover this but I have not been able to find it so I will ask again. What do you use to secure the drawers in an expanda to stop them jumping out while you are traveling?
I'm having trouble with the drawer under the cooktop. It is fairly well loaded up with crockery and glasses and likes to bounce out on bumpy roads ( we have more than enough of them in South Australia ) and cornering. We have broken a coupla cups and glasses already but being a pop top there is not really anywhere else to put them.
I'm thinking there must be a good bar system to secure the drawer but I wonder what others use, if anything?
20,096
Been racking the brain trying to recall but to no avail, throw a pic of the lock thats fitted ....................... There was something about a pin and spring in one model that was a cause as well the drawer catch getting bent so the latch wasn't catching fully, so have a look and the tab to see if its been bent, if plastic might be worn.
Is the draw a wood on wood slide or an actual rail slider, either way wood on wood could have worn allowing the drawer to drop and make for an easy release or with a slider a couple of screws could have come out or loose causing the same thing, van builders seem to love metal self tappers for timber work, so they fall out often.
Just a stab in the dark ................
Reactions: Disco Duck
704
sounds like the existing clip/lock just needs some help there some pretty good magnetic cupboard latches on the market also child proof cupboard locks which can be added to help the exixting closure, if all else fails there is always the old hook and eye door latch .not pretty but will keep anything closed
858
I upgraded a couple of heavy drawers with proper bearing slides from bunnings. This prevents the wild movements of the fairly basic tracks I have in mine. I would also check the metal tang mounted on the cross beam (assuming the latch uses a pushed up bar to hold) that the lock only just clears it when open and there is no forward/back movement when locked. Otherwise a simple disc, drilled with a hole near the edge, screwed above the drawer - on the cross beam, would work. It would then be rotated slightly out of the way to open the drawer. Wouldn't need to be tight as it's only a fail safe device
704
Onya Guys. I'll have a big think about it and see what I can come up with. I'll let you know what I do.
I'm a bit concerned about using the child proof cupboard locks as I may have to open the drawer myself
ah! old age is a brutal task master, my three year old grand son loves going thru the van and unpacking the draws ,all was good until he came out with a fishing knife from the cooking drawer right in front of his mother, i fitted a child proof lock to that drawer that allows the drawer to open about and inch then you have to push down a clip with your finger to open the drawer, peace lasted for about five seconds until he found he could open the drawer using a spoon from the drawer above, now no sharps are allowed where i want to keep them, BTW that drawer never comes open by itself no wood butchery needed just a couple of screws each end and you cant see it
Disco Duck
315
586
Three year olds...................gotta love 'em !!!
I like the idea of the disc Jazzeddie, Simple but effective and even I can open it.
Than you for your help boys. I will get it sorted now.
