Jayco Truma Aventa Air Conditioner problem...
BJM
485
549
Yamba
Away 9 weeks again last year in Qld and the tv didnt get out of its bag.!Geez some people carry more gear than a tv
outside broadcast van.!
Reactions: chartrock
427
Quick update, took the van to have the air cond looked at. Turns out it was the Temperature sensor that had failed, which just locked the unit from starting. $35.00 for the sensor and $180.00 to have it fitted. Not a bad result I thought. The TV works fine too when there is a half decent signal!
Wazzar
Penrith
Truma Red Light Fault
I found this forum about The Truma Adventa Roof air con as I had a red light fault as well and couldnt find a fix. I did all the reset tricks as the book states and no luck. My local Air con guy sort of pointed me in the right direct reluctantly and I went searching.
So this is the problem and the fix as it worked for me 100%. The air unit over many years condensates on the inside and moisture runs down into the IR dome causing the pins to rust. So a $9 IR from Jaycar and some light soldering will fix your problem.
YOU WILL NEED A VERY SMALL TORX BIT to remove the board from the aircon panel (or a custom ground flat blade screw driver).
This board new is $360. so a $9 fix is worth a go anyday. You also need to pair the remote to IR as per booklet.
Good luck. Let me know how you go.
See the pics ive attached.
auspoweng
Wazzar, Fantastic info mate. I went looking everywhere for the some info on what what IR receiver component it was and you did it! Problem is the site isn't loading your pics on this thread. Any chance you can post the Jaycar part number? Im assuming it is Cat No: ZD1952
Nessant
Just encountered this problem today, pins don't seem rusty, however I'm keen to give it a go.
Unfortunately I can't see your pics?
