Jayco Safe
Aug 29, 2013
70
27
Warradale SA
Hi All,
I've been trying to figure out if there's any special way of opening the safe in our Expanda, I've tried to insert the key and for the life of me can't open the bloody thing, I've done a search and can't find a thing.
Look forward to hearing some good replies and no bad ones hopefully.:peace:
Gavin
jeff
413
414
200km south of Perth
Don't think there is special method, I insert the key, give it a turn & then I pull the inner draw out. There is just enough room to slide it all the way out
Glen Bundesen
336
212
Perth WA
Don't know if all the vans have a key with a notch on it. I insert the key with the notch straight up and turn it clockwise...
*Try posting a bit more so your post isn't boring* - I have a larger electronic one out of my Flaming go to go into the spanda
I think its job #78546 on toilet roll #8
have to double check later.....
can the one in there be removed? only looked at it when we did hand over and forgot all about it
hamish22
742
641
West of Newcastle
www.grmotorsport.com.au
Hi All,
Gavin
Leave it, I can't get mine to bloody shut!
Marv_mart
1,275
2,019
With my 14.44-5 OB, they placed the small safe in the bottom shelf under the wardrobe. Such a stupid position that the whole shelf was wasted. Couldn't slide in any storage boxes. Ended up taking it out. Might fit it in the small cupboard up high under the pop up roof. Out of the way but still easy to access. Getting it out required Y to go under the van and grip the lock nut with me inside with a long shaft Philips head to undo the screws. Not sure yet as size isn't big enough to put in stuff I might want to lock away eg iPads etc.
