Looking good @Jasman, welcome, when is pickup day?
Should be next Thursday all things going as planned. Good to see another Toowoomba member!
Hey, thanks for the reply. I found the bulletin from back in 2011 that made that recommendation but I had a look in the manual and it is ambiguous to say the least so I sort clarity for insurance purposes etc and went through the process with Jeep and the end advice was it isn't necessary and is not recommended. I'm not going to make a blanket statement and say it's not required but the advice they have provided in my instance is not to use it.
I spent a lot of time looking in to the use of a WDH on the Jeep. I also rang Jeep several times and got no real definite answer to use or not to use.
Did you get anything in writing from Jeep Australia stating a WDH is not required?
I have towed my van with out the WDH and the Jeep feels light in the front end and unsafe and all overt the place at anything over 90km/h.
I ended up buying and Andersen WDH for my van / Jeep combination and would not tow without it ever again. Makes a huge difference, I now tow at 100 + km/h and can overtake with ease and the Jeep feels solid and very stable. It is now a pleasure to tow and I feel safe.
I'll go with jockey wheel holder.Ok, so went down today and had a look at her in pre-delivery and now I'm starting to get excited.
Check out the photos below, you'll note I've got an extended drawbar with a factory fitted jerry can holder (I haven't seen this on any others). Anyone have any idea what those clips are for on the inside of the jockey wheel?
For storage as you drive?????That's the only thing I could think of that would fit in that clip but why would you have a clip to hold the jockey wheel let alone two?
Hey John,Hi Jas,
Do you have the new Expanda home in Toowoomba yet? A couple of pictures would be good.
John
looks good.............
did you ask about those 2 brackets in the middle of your draw bar..............?
