G'day all we'll we are on our big trip up the centre and are now at Townsville for a few days and it's great. had some issues with our expanda so thought I mite share
Usual draw issues
Internal lights fuses blows when we travel and I can't pin point the fault have pulled all lights apart and all looks good
Outside speakers have stopped working
Was just about to leave mt isa and was came out to the car park and found the one tyre half flat and thought I will just plug it and keep going but couldnt find a leak so changed the wheel and took it to the tyre service and we found the rim had cracked on the radius of the rim??? On closer inspection it looks like a casting defect but it has ran a inch either side of the small hole. Contacted page bros who were great and they contacted Townsville jayco for us so we elected to high tail it today to Townsville and went to jayco and I will say the help there was appalling as they basically fobbed us off and said it would take two weeks to get a rim sent from Melbourne I asked if I could take spare from there vans in stock and they replace it and they weren't interested... Have decided to contact page Monday to disuss and based on ther response I will go to a tyre service get the tyre removed then Drill two small dimples either side of the hair line crack and then get a tube fitted
Last night in hughenden when we came back to the van and went to unlock the door and the key would not go in the barrel and we could t get in so I sent the young bloke in through the pop top section under the awning to open the door but it was jammed so I crawed through and had to dismantle the lock assembly and open the door??? And then try to repair the barrel but the internals have collapsed..... I got the door to finally work but we couldnt lock it which is ok. So spoke with jayco in townsville today whilst trying to get anew rim and they had a service guy ther and didn't even look at and but they will Monday morning. I said give me the lock and I will fix it and the reply was you will loose your warranty....
Not a happy camper with what they say a Australia. Wide warranty and service...
Anyway if anyone has advice will appreciate the feedback... Still the best holiday though
Usual draw issues
They came to their senses & agreed to replace the spare with a new one
, but now i'm sus on the wheel that was the spare & is now in use, it visually looks like it could also be losing pressure.
