So following on from my newly found knowledge of Solar, Batteries and everything in between I ask myself are the 200W blankets with the supplied controller really the value they seem?
I tested my blanket with no controller/load attached - it had an open voltage of 24.9v. This was on a clear day when the sun was directly overhead and the blanket laying flat.
Ignoring losses for cable quality, etc I *think* the below is correct.
Since the PWM controller clips this down to 13.5 (not programmable) you can only ever harvest approx 24.9/13.5% ~ 55% or the claimed 200W, or 110W.
Where you *may* get some of the value back (over a smaller blanket) is when you are in less than perfect conditions (ie. you may only be harvesting 18V - where a smaller rated panel may only harvest 14V (which is not enough to turn the controller on)).
Just my thoughts.
Once I get the MPPT charger I've love to do a comparison between the outputs "in perfect and not perfect" conditions and compare a better controller (and see if the value is really there for a better controller).
Just my thoughts.
