Interior Interior trim around window
Dantheman
5
7
Lismore
Hi all,
I need to replace the bottom interior architrave on the small window above the sink. It was burnt by a candle. Images attached.
Does anyone know where I could get this part?
Thanks, Dan.
19,507
You would have to know the window brand to possibly find parts at CaravansPlus, being a blind unit remove carefully I assume, I would remove and do a touch up job on it depending on what its made of will determine the procedure, probably require the whole frame to be done so it all looks the same.
734
I have them in my jayco so you could try a dealer. They are easy to remove/install so long as the top and bottom blinds are clipped together. I hear (cough) the 2 sides can be installed either way but the lock positions are in the wrong place...Not that I would know
