My advice would be to have a chat with your licensed gasfitter who will sign off on the job before you go too far. If he is happy with the location then all good. The location of the heater needs to conform with AS 5601. Appendix J of AS 5601 goes into locations of LP gas bottles and clearances to ignition sources. As an rough example and there is more to it, gas bottles have to be 1.5m away from an ignition source. Your heater may be 1.5m away but it may depend on where the flue/air intake is installed. Can be a few grey areas, such as bottles being around the corner etc, flue being deemed a mechanical air intake etc etc.
I had a look at the installation instructions and on Page 7 states must be installed as per gas regulaions AS 5601. Although the manufacturer puts guidelines in their instruction, they always state must be installed by licensed gasfitters etc etc and they always say must be installed as per AS 5601 (gasfitters bible/laws). This has other installation rules which come into play.
I hope I have not confused you, I would hate to see you do all that work and cutting only to find when you get it checked and finished by the Gasfitter, he says" why did you put it here".
Cheers Geoff
Cheers Geoff
