Excellant write up @cruza driver but using a metric adjustable spanner tsk,tsk............lol.
Does anyone know if the bearings are the same through out the Jayco range or is it likely that the OB's are different to the standard vans?G'day CG
INNER BEARINGS 3201J-L WITH THE BEARING CUP THE SAME NUMBER
OUTER BEARINGS 4T-15123 BEARING CUP 4T-15245
Great advice @Drover@drover: 104568 said:Mine has 12" ALKO off road drums.
They have big bearings similar to your 4x4 bearings so you should always carry a spare set as they may not be at your garage when you need some unlike the smaller Ford or Holden trailer bearings.
To be sure you buy the correct ones just pull the hub off and rock up to your bearing shop with it, saves finding you have the wrong ones out at Cunnamulla.
Inner Bearing 30210 with cup.
Oil seal TC12631
Outer bearing 15123
Outer Cup 15245
Set you back about $60.
I have pre packed mine wrapped in glad wrap and vac sealed for freshness. Just in case I forget to pack any grease.
Maybe start a thread for that ...Might be an idea if folks ID their hub ie: 12" ALKO off road or 10" whatever and state what bearing set they have fitted, might help someone who's stuck.
Van model and style has no bearing on what is fitted in the hubs of course. I find it strange that mine had 12" off road hubs with slipper springs on a tour model, (originally that is, it's a hybrid rig now).
Anyway just an idea. PS: to my earlier post don't forget to pack a couple of new split pins.
Depends on what brake drum/hub is fitted not what the van model is. ALKO drums have a number stamped on them which you can cross reference to see what bearings are fitted to that hub otherwise it's pull the drum off and have a look at the greasy bits, always the better option as then you are positive. I have carried a set of bearings around for years and then found they were the wrong ones.
It was worth a try.![]()
