I am looking at wiring a hot hire from the battery to a 12 pin plug at the rear of the tug to power the fridge while I drive. The question I'm ask asking is should I use 6 b&s cable and will it fit into a standard 12 pin socket or can I get away with normal 6mm cable. I have been doing some research and I'm confused which isn't hard. I have contacted jayco and was informed normal 6mm wire would be fine without any voltage drop. Does this sound right?...
