With all this talk of heaters I have been doing some research on Gas vs Diesel.
I am not convinced on the diesel it is obviously cheaper to run from looking at the specs.
But I can not get my head around having a separate fuel tank that requires diesel fuel in the van and a diesel motor running in the van whilst releasing diesel gas as well to the outside.
So what makes diesel so special compared gas?
Looking at the gas option I already have two 9kgs bottles so approximately 100hrs of heating only use on gas for the Truma unit so more than ample heat time.
Its a smaller install for gas as it only requires a vent to the outside and some games pipes instead of the diesel which needs a big hole for the units exhaust pipes, fuel tanks, fuel filler neck, fuel lines etc etc.
So is there a huge performance difference between the gas or the diesel or another reason I am missing why people are going the diesel path?
